Use the phone
Once your phone is connected to the car, you can use voice commands to e.g. call a contact or phone number, or to listen to a message.
Using voice recognition control to make a phone call.
To activate a command
Common commands/phrases
- "Call [First name] [Surname]" - calls the selected contact from the phone book.
- "Call [First name] [Surname] [number category]" - calls the selected contact from the phone book when the contact has multiple phone numbers.
- "Call [phone number]" - calls the phone number.
- "Recent calls" - displays the call log.
- "Message to [contact]" - you are prompted to speak a short message. The message is then read back and you can choose to send it or re-record the message. For this function to work, the car must be connected to the Internet1.
Numeric commands are entered differently depending on the function to be controlled.
Telephone numbers and zip codes must be stated individually digit by digit, e.g. zero three one two two four four three (03122443).
General commands
The following commands can be used regardless of the situation:
- "Repeat" - repeats the last voice instruction.
- "Cancel" – terminates the dialogue.
- "Help" – starts a help dialogue. The system responds with commands that can be used in the current situation, a request or an example.
