Downloading files and updating voice control
You have the option of updating the system to improve your use of voice control in your vehicle. Below is a description of how to download new voice control files and update your system.
Preparations
The files can be downloaded to an empty USB memory of at least 8 GB. The memory must have one of the following formats: FAT32, NTFS or exFAT.
Download program
Voice control files are downloaded using a program that is installed on your computer in connection with the download of the voice control file.
Updating voice control files
The relevant updates can be found under the tab for software and downloads. You access the information for the relevant car by selecting your car and model year. Click on the update you want to make and then follow the instructions below.
Insert the USB memory in the USB port. If there are two USB inputs the second one must not be used at the same time.
When the installation is complete a notification is shown advising that the updated file is available after the next restart. The USB memory can now be removed.
If there are any problems with the update, contact your customer support or Volvo dealer.
Updating tips
An update takes about half an hour and the infotainment system must be on. Use a battery charger or keep the car's engine running while the update is in progress, for example during a trip.
Download map updates
You also have the option to download map updates to your car. For more information about how to proceed, see Map download for Sensus Navigation.
