Adjust the climate
To start voice control of the climate control system, use the command "Climate". A dialog then starts and examples of commands are shown.
Using voice recognition for climate control
To activate a command
Common commands/phrases
- "Set temperature to X degrees" - sets the desired temperature1.
- "Raise temperature"/"Lower temperature" - increases/decreases the set temperature one step.
- "Set fan to max"/"Turn off fan" - changes fan speed to Max/Off.
- "Raise fan speed"/"Lower fan speed" - increases/decreases the set fan speed one step.
- "Turn on auto" - activates the automatic climate control system1.
- "Air condition on"/"Air condition off" - activates/deactivates the air conditioning.
- "Recirculation on"/"Recirculation off" - activates/deactivates air recirculation.
- "Turn on defroster "/"Turn off defroster" - activates/deactivates defrosting of the windows and door mirrors.
- "Turn on seat heat"/"Turn off seat heat" - activates/deactivates seat heating2.
- "Raise seat heat"/"Lower seat heat" - increases/decreases the set level for seat heating one step2.
- "Turn steering wheel heat on"/"Turn steering wheel heat off" - activates/deactivates steering wheel heating2.
- "Sync temperature" - synchronizes the temperature for all climate zones in the car with the temperature set for the driver's side1.
- "Turn on rear defroster"/"Turn off rear defroster" - activates/deactivates rear window and door mirror defrosters.
- "Air on feet"/"Air on body" - opens the desired air flow.
General commands
The following commands can be used regardless of the situation:
- "Repeat" - repeats the last voice instruction.
- "Cancel" – terminates the dialogue.
- "Help" – starts a help dialogue. The system responds with commands that can be used in the current situation, an instruction or an example.
