To create a Bluetooth® connection, see the video tutorial or follow the instructions below.
If a new device is connected with the same name as a previous device, the previous device may need to be deleted first.
Pair your Volvo with a Bluetooth® device
There are two different versions of the infotainment system. To see which version is in your vehicle, check if you have the connection button. If present, go to section Sensus Connect, otherwise go to section Sensus.
